1.07 not working, Stick with earlier version
Discussion in 'Appointway WordPress Theme' started by ja1nsa, Jul 4, 2013.
  1. ja1nsa
    ja1nsa Member
    I have tried the following:
    1. Install standard WP theme, delete appointway theme, FTP appointway theme.
    2. Use FTP to over-write existing appointway theme files in wp-content/themes
    Neither work. The CAPTCHA does not work, the appointment form now becomes a plain text form.
    Please refund my account as the support is almost nil and I have been waiting 2 weeks since 1.07 was released with a net result of a solution that works less well then the original 1.05.
  2. ja1nsa
    ja1nsa Member
    ok, I set-up a brand new domain and loaded WP from scratch along with appointway 1.07. All looks better with form displaying correctly and in widget. Basic Captcha also present.
    Can you please now advise how I get my website at www.011-electrician.co.za to work without having to follow the steps above. i.e. I tried FTP with over-write. I deleted appointway from wp-content/themes and reinstalled, but does not work. If I need to perform a free install of wordpress I will lose all the work so far. I need a step by step guide please.
    ps - why can I not simply do an upgrade of the theme from within wordpress as most theme providers supply!
    J.
  3. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    And also provide the list of your issue which you are getting, We will solve it.
  4. ja1nsa
    ja1nsa Member
    Gourav
    I have provided this previously. I have several threads open as I am told to create separate threads (as above). Please check. I have also emailed the details. I do not want a quick fix from you guys in case I want to implement. Frankly, this is getting tiresome.
    Regards
  5. ja1nsa
    ja1nsa Member
    Hello, anyone responding? A fresh install of wp and theme works. Upgrading from earlier version does not. I need instructions. Tried FTP, delete theme then install new version, nothing works.
  6. Nitesh
    There is no need to go through FTP.
    Just go to your dashboard. Activate WordPress default theme like "Twenty Ten" and delete "Appointway theme".
    After that click "Install theme" and upload updated theme from your system.
    Or
    Just rename updated theme which you have downloaded from your members area.
    After that click "Install theme" and upload renamed theme from your system.
    Note:- If you are doing some custom changes in the themes .php files then you can use child theme to save your changes.
    Follow link given below for more info about child theme.
    http://www.inkthemes.com/httpwww-inkthemes-comhow-to-create-a-child-theme-in-wordpress-a-way-to-save-themes-modification/02/
  7. ja1nsa
    ja1nsa Member
    Yes, I tried that. I already posted it did not work? Hence I tried the FTP route.
    On trying the above again, I now see new options in the theme? Custom Leads Form" and "Lead Capture" ... hmmm. I will try it out later today and advise.
  8. ja1nsa
    ja1nsa Member
    ok, this is a new version? It is different to my original 1.05 and different from the 1.07 I loaded on a fresh WP install??
    1. There is no captcha - there was on fresh install
    2. All fields are now required
    Guys, you are making this VERY difficult!
  9. Nitesh
    Please provide dashboard detail of both of your sites.
    I will update them to the latest version and also resolve issues you are talking about.
    I know that you have already sent before but don't know why i am not getting.
  10. ja1nsa
    ja1nsa Member
    Resolved, but recurring on www.sensational-blindsandflooring.co.za ?? I copied over the plugin files from the www.alarms4u.co.za which is working fine, but can't get the rendering? is this my theme and sidebar width? what is it? driving me mad I cannot fixed and have to keep asking. Please supply details of what is changed.
  11. Gourav
