1 Click Install
Discussion in 'RoadFighter WordPress Theme' started by lavinders, Jun 11, 2013.
  1. lavinders
    lavinders New Member
    Hello, I just installed the roadfighter theme.
    Where is the 1 click install button? I installed and activated the theme. I dont see any sample content other than whats on the home page. Is there more sample content, or is that it?
    Lavi
    Thanks for asking your doubt. One click installation simply means that once you click on the activate button, the theme will be automatically set on your website with default content and menus, which you further can modify. There is nothing called button given for that. You have to makes changes after the installation
    I hope you will understand and cooperate.
