13 Plugins
Discussion in 'Viral Plaza WordPress Plugin' started by ninjainktheme, Jul 16, 2013.
  1. ninjainktheme
    ninjainktheme New Member
    Where do I get the 13 plugins...
    Leon Williams
    You have purchased the theme membership for $147, that doesn't include the plugin membership.
    If you want to purchase the Plugin membership also, then follow the link below.
    http://inkthemes.com/members/signup/index/c/je5mkAMg
    You can purchase full membership of plugin for just $97, and after that you don't have to pay any monthly amount for plugins.
    Our plugins are very simple and easy to use and they all are compatible with InkThemes.
    I hope you will find it easy and simple to use. Thanks a lot for showing your interest towards InkThemes plugins.
    You are an awesome customer.
