$149 Package
Discussion in 'InkThemes-Support Working Hours' started by pulidoae, Jul 25, 2017.
  1. pulidoae
    pulidoae New Member
    I just purchased this package and I don't see the wedding dj theme in there like on the website. How do I get that theme?
  2. akbar92
    Hi Andrew,
    I would like to tell you that Wedding DJ is a marketplace theme.
    It is not a part of the $147 Membership Bundle.
    By paying $147, you will get access to 49 themes initially.
    Further, if you continue to pay the $15/month i.e. monthly subscription, you can claim either a Theme or a plugin per month as a Bonus.
    If you are interested in $147 plan, you can check it out here :https://www.inkthemes.com/offers/inkthemes-membership/
    For now, I have added the Wedding DJ Theme to your account.
    We have provided JSON and XML files along with theme ZIP and Import Export plugin.
    You need to install the ZIP then the plugin then download and import the JSON and XML files
    You will get the theme as shown in the Demo
    Hope this helps!
    Akbar
