2 Questions
Discussion in 'Gommero WordPress Theme' started by itzcandy, Feb 3, 2016.
  1. itzcandy
    itzcandy Member
    1. I keep uploading a new image under Appearance/ThemeOptions/GeneralSettings/BodyBackgroundImage and it will still not change?
    2. I would like the title container boxes of the feature areas to be solid blue.
    Thank you,
    Candy
    Hello Candy,
    Regarding your first issue,
    You are suggested to deactivate all of your plugins first and check after that..
    For the second issue,
    Firstly you have to follow the screenshot given below.
    Now please paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .feature_content .feature .feature_title {
        color: blue;
    Change color as per your interest..
  3. itzcandy
    itzcandy Member
    This did not fix either problem.
    I want the boxes blue like the attached image.
    The background will not change. I upload the image in Theme Appearance and hit the save/submit button and it does not save the change.
    Also I would like all of the links in the main menu to be blue.
    Thank you
    I apologize actually I thought you were interested in changing font color over there..
    To change box color,
        background: #4169E1;
    To change the menu link...
    Firstly you have to disable cufon as I have mentioned in my first post and after that paste the code given below in Custom CSS field of your dashboard.
    #menu .ddsmoothmenu li a {
        color: blue;
