2 questions
Discussion in 'Dzonia WordPress Theme' started by deveshd, Aug 13, 2013.
  1. deveshd
    deveshd Member
    1. I'm using the latest version of Dzonia theme but the slider is not automatically sliding/ changing in some browsers, I noticed this in IE and chrome. Any work around?
    2. Which page builder plugin you recommend to use with dzonia theme if I had to build inside pages (formatting and columns, boxes etc)
    URL: http://webworxworld.com/client-demo8
    1.For your first issue
    We have checked your website and there is no problem with the slider in the site. Please check your website again after clearing cache and also check your site at any other browser.
    2.For your second issue
    There is no need of using plugin for columns, You can shortcodes for that.
    Follow the link given below
    http://www.inkthemes.com/how-to-use-shortcodes-in-themes/02/
    I hope it will helps you.
    or
    Go to WordPress.org and search plugin for your requirements and upload it.
    http://wordpress.org/plugins/
  3. deveshd
    deveshd Member
  4. Piyush
    Design you are asking is not possible with any plugin or shortcode.
    You have to design it manually by yourself.
