3 question for homepage
Discussion in 'One Page Pro WordPress Theme' started by shaunling, Nov 3, 2016.
  1. shaunling
    shaunling New Member
    Hi Support,
    I have one issue and a requirement need you help:
    This is our website:
    http://www.pengerangaccommodation.com/demo/
    1.) the pricing field is slow and need drag to the very depth place the pricing finally comes out, can help me solve this?
    2.) Can I add the dropdown selection input type in contact us section. if can you can just give me the code to paste to contact us template.
    3.) Can I open back the banner title in mobile mode, cuz the banner title is hide in mobile.
    Thks.
  2. shaunling
    Any reply please, one answer only also can.
  3. nitin
    nitin Guest
    Regarding the Pricing Section, I would like to let you know that the delay which you are facing is a part of the animation that's integrated with the theme. You have entered a large amount of content which makes the delay even longer. To solve this, you can turn off the animation for the website, so that the contents will load instantly on your website. To do this, just go to Customize -> Theme Settings-> General Settings -> Theme Animation On/Off Settings and turn the option to OFF.
    Next, could you please elaborate in detail which specific type & how many drop-downs you need in the section, so that we could assist you accordingly?
    Regarding the banner title, you would be glad to know that YES, we could open it up for you even in the mobile mode. We visited your website, but couldn't locate the banner title anywhere. Could you please provide edited screenshot of the concerned area, so that we can assist you accordingly?
    Looking forward to hear from you.
    Nitin
  4. shaunling
    Hi support, thks for reply:
    1.) the pricing:
    I try disabled the animation already, but when scrolling to pricing "title" place, the pricing still cannot comes out, I know it was information too long, but have a way to disable the "scrolling item comes out" effect in order to let pricing comes out first?
    2.) You can see the form requirement screenshot in attach.
    3.) You can see the form requirement screenshot in attach also.
    Thks so much!
    Hope reply soon.
  5. shaunling
    Hi support, can reply following questions?
  6. nitin
    nitin Guest
    Hope you are doing good...!
    To do the required changes, it will require some customization in the source code of the theme for which we need access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password :
    We will do it for you.
    Nitin
