4 Column Sidebar Footer
Discussion in 'VideoCraft WordPress Theme' started by dahdesigns, Aug 5, 2013.
  1. dahdesigns
    dahdesigns Guest
    I would like to have the four column sidebar footer for this theme. How can I get that done? Also, my footer menu has disappeared. How do I get that back?
    Unfortunately there isn't a way to make the four column sidebar footer for this theme unless you custom code something up, sorry.
    By default the footer menu is displaying in the footer widget area.
    Go to the Appearance > widget in your dashboard and remove all the widget from the First Footer Widget Area.
    This will show the default content in the footer widget area i.e Footer Menu.
  3. dahdesigns
    dahdesigns Guest
    Are you able to answer the other question?
