7,8,9 home slide
Discussion in 'RoadFighter WordPress Theme' started by webdatabank, Nov 14, 2013.
  1. webdatabank
    webdatabank New Member
    i need to increase the photos in the slide home from 6 to 9 (or more), how can I do?
    I apologize for the bad english, I'm using google translated from Italian.
    Wordpress is mounted on www.studiocassa.it /website.
    Bye!
    Theme already contains 6 image to slide in the slider that is enough for the theme.
    If you required more than 6 slider image then it required lots of customization in the theme,
    so it is not possible for us to do that with this theme unless you custom code something up. Sorry.
  3. webdatabank
    If you kindly tell me which files I'll change. I do not want to know how, then I arranged it alone.
    Thank you.
  4. Piyush
  5. webdatabank
