A Couple of Questions
Discussion in 'Appointway WordPress Theme' started by bizgirl, Feb 25, 2017.
  1. bizgirl
    bizgirl Member
    Hi there guys.
    Would really appreciate your help with CSS code the following 3 questions.
    1. How to remove the phone image and tap to call. I tried some CSS I found for this in the forum but it did not
    work.
    2. My client would like the menu bar color changed to gold. Could you provide with code to do this and the
    code for the text color also.
    3. Could you please provide code to change the hover color and text color.
    Site is www.keziahsreadings.com
    Many thanks as always.
    Maggie
  2. nitin
    nitin Guest
    I would be assisting you on your issue(s) one-by-one :-
    (Dashboard-> InkThemes-> Styling Options -> Custom CSS) of your dashboard.
    .call-us p:before {
    @media only screen and (max-width: 768px){
    .taptocall {
    Use the custom CSS code mentioned below:-
    .menu_container {
        background: #d9b1f9;
    Note:- The above value for the color code is the one that is presently set in your theme, please change the values accordingly
    #menu li a:hover {
        color: #facff5;
    Hope this helps...!
    Nitin
    bizgirl likes this.
