A couple questions
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by maitredesjeux, May 1, 2015.
  1. maitredesjeux
    maitredesjeux New Member
    Hi!
    I love your theme by the way, it does what I want to, but! I would like to change a couple things and I would like to know how.
    Is there a way to remove the "demo" text that is there before I fill in the blanks? I would like to have my first slide witout text on it.
    Is there a way to have the same categories in the search bar as my product categories. Or even just adding more choice to the shop search options. Instead of more popular, most recent ect.
    Thanks!
    JF Meloche
  2. praveen
    praveen Support Staff
    Hello, JF Meloche!
    1> Please follow the screenshot given below.
    2> Could you please provide us some edited screenshot of your issue so that we can assist you accordingly?
    In case you are unable to create a screenshot, you can follow the link http://www.screenpresso.com/ which will help you to create screenshot easily.
    Praveen
