A few colorway questions
Discussion in 'ColorWay WordPress Theme' started by antoniamaslin, Jun 30, 2013.
  1. antoniamaslin
    antoniamaslin New Member
    Hi
    1. How do I remove the black lines above and below the menu?
    2. How can I add widgets to the bottom of the content area on the front page? Ideally I'd like 3 columns that I can put widgets in.
    3. How do I increase the area between the logo and the menu bar
    Thanks!
    1) Paste this code in Custom CSS
    .header .menu-bar {
    border-top: none;
    border-bottom: none;}
    2) You can add widgets in the footer widget area.
    Just go to the
    Appearance > Widgets
    Drag and drop widgets of your choice to the footer widget area.
    3) Paste this code in Custom CSS
    .logo {
    margin-bottom: 50px;
  3. antoniamaslin
    Hi
    Thanks for that.
    With the widgets I just want them on the homepage - how do I do this?
  4. spoonboy90
    spoonboy90 Active Member
    Try 'Display Widgets' plugin from Strategy11. used it on many inkthemes themes with no problems... allows you to hide or display widgets on specific pages
