A few edits for Bizway..help
Discussion in 'BizWay WordPress Theme' started by treebee, Dec 8, 2012.
  1. treebee
    treebee New Member
    There are a few edits I have been trying to make on the bizway theme but cant figure it out.
    Slider:
    • How can I remove all the slider navigation (arrows and dots) and is there a way to change the transition from slide to fade?
    Menu
    • How can I change the active and hover colors?
    Background
    • How can I stop the page from scrolling over the background image- I'd like them to move together if that makes sense?
    Thanks so much for any help!
    1.For your slider issues
    Paste this code in Custom CSS
    .flex-control-nav {
    .flex-direction-nav li .next {
    .flex-direction-nav li .prev {
    Now,
    Go to Js > jquery.flexslider-min.js present in your theme directory and search "defaults" you can find only two result for it, go to second result and follow the instruction as shown in image given below
    2. For you menu issue
    #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li a:hover, #menu li.current_page_item a{
    background:red;
    Inplace of "red" put your color code.
    3.For your background issue
    Go to "header.php" present in your theme directory and remove the code given below
    fixed
    Sending image for reference
  3. treebee
    treebee New Member
    You are a god send! thank you so much for the detailed assistance:)
    Nitesh likes this.
