A Few Questions Concerning GeoCraft (V2.0) Theme
Discussion in 'GeoCraft WordPress Theme' started by aunjar, Nov 26, 2014.
  1. aunjar
    aunjar New Member
    Website: http://www.chocolatetherapyforwomen.com
    1. I changed the speed of the carousel. It works fine on mobile and tablet, but seem it no longer auto scrolls on desktop. Any thoughts what might be wrong?
    2. How do I change my "Listing Categories" to look like this one: http://uk-businessdirectory.org.uk/
    * Font is smaller and they are showing category and sub-category. How can I duplicate that?
    3. How do I change the background color of the Premium listings from gray to something else?
    4. I am using an event plugin called "The Events Calendar". However when I try to view my events at http://www.chocolatetherapyforwomen.com/events/ all I get is a page showing that shows premium listings. Is there a fix for this conflict? Should I use another plugin? Do you have a recommended event plugin?
    Thanks!
    BTW, GeoCraft is a Great Theme!
  2. Pramod
    Pramod Guest
    1) Due to changing the speed some script generates error you have to put old carousel file .
    2)You cannot do changes because we have updated theme version and many code has changed. That theme's version is 1.7 approx.
    3)
    Use below CSS code in theme option and change color according to your need.
    .content_wrapper .featured_content .featured_post .featured {
    background: #FF1010;
    4)
    You have to check another alternative plugins for that. We have no recommended event plugin.
    Pramod
    organic likes this.
