A few questions on logo
Discussion in 'ButterBelly WordPress Theme' started by sangermike, Nov 28, 2014.
  1. sangermike
    sangermike Member
    1. How can the logo be aligned to the left
    2. And is there a way to overlap the logo on the nav bar?
    3. OR is it possible to put the logo right on the navigation bar so I can either use the opacity header for a dif purpose or take it out
    URL: www.allmetal101.com
    Thank you.
  2. Yogesh
    Yogesh Guest
    .logo {
    text-align: left;
    .logo img {
    margin-top: -70px;
    .header_container {
    z-index: 1;
    #menu .ddsmoothmenu li ul {
    z-index: 11;
    In small view your menu will overlap by logo so i advise you not to use following code in from above code.
    .logo img {
    margin-top: -70px;
    It will resolve your issue.
    Yogesh Bhade
  3. sangermike
    sangermike Member
    Will that still be the case if the logo is flushed more to the left? or if the menu if aligned to the right?
  4. Yogesh
    Yogesh Guest
    #menu .ddsmoothmenu {
    text-align: right;
    Yogesh Bhade
  5. sangermike
    sangermike Member
    I really like the way it looks on the desktop. But as you warned it overlaps in smaller view :( No other solution? Thanks
  6. sangermike
    sangermike Member
    Thanks Yogesh. You can close this one. I just won't display the logo on mobile.
  7. Yogesh
    Yogesh Guest
    @media only screen and (max-width: 767px){
    .logo img {
    margin-top: 0px;
    max-width: 100%;
    @media only screen and (max-width: 960px) and (min-width: 767px){
    .logo img {
    margin-top: -25px;
    Yogesh Bhade
