A Small Tip
Discussion in 'ClassiCraft WordPress Theme' started by amaconline, Jul 18, 2013.
  1. amaconline
    amaconline Member
    Hi, currently logged-in username does not appear on the top to say who is logged in. However, I have managed to code it round to show which user is logged in on top of the page. See screen below:
    If you want to know how I have done it then let me know.
    Thank you.
  2. sooraj
    sooraj Member
    India
    Sir
    i want to do this pls help thanks
  3. amaconline
    amaconline Member
    1. On your Wordpress dashboard go to Appearance à Editor
    2. On the Edit Themes select “Header.php” from the “Templates
    3. Scroll down until you see the <body> tag
    4. Under the <body> tag look for the line: <?php if (is_user_logged_in()): ?> and paste the following code under it:
    <?php
    global $current_user;
    if ( isset($current_user) ) {
    echo $current_user->user_login;
    Save it and you are all done.​
  4. calvinhon
    calvinhon Member
    But make sure you change your URL link to your Domain URL and not copy amaconline exactly. For example, instead of using this:
    <img src="http://www.easternglobe.com/wp-content/themes/classicrafttheme/images/dashboard-icon.png">
    <?php
    Make sure your URL Domain name is being replaced like this:
    <img src="http://www.xxxxxx.com/wp-content/themes/classicrafttheme/images/dashboard-icon.png">
    <?php
    Just to make it clearer from what i've said, my URL Domain is www.isniffy.com, right, so it should be like this:
    <img src="http://www.isniffy.com/wp-content/themes/classicrafttheme/images/dashboard-icon.png">
    <?php
    Hope this helps!
  5. dailypaymentjobs
    dailypaymentjobs New Member
    Hello friends,
    I have tried.. but its not been changed..
