A warning appears when I tried to delete an expired listing from my dashboard.
Discussion in 'GeoCraft WordPress Theme' started by aliounn, Jan 31, 2013.
  1. aliounn
    aliounn Member
    Hi support ,
    I have just tried to delete an expired listing from my dashboard by clicking on the delete link. After that, this warning appears at the top of the page. when i sign out, the warning is still there.
    Warning: array_merge() [function.array-merge]: Argument #1 is not an array in /homez.635/adopteuns/lyon-beauty-shop/wp-includes/post.php on line 2996
    How can i resolve this issue ?
    Geocraft owners ,can you try this manipulation to see how it goes with your theme ?
    thank you.
    I file attached.
      File size:
      53.9 KB
      5
  2. aliounn
    aliounn Member
    Once again, I tried to remove a second, and a third listing, which returns three warning !!!
    The removal of published and pandding listings does not return a warning. It is only for expired listings.
  3. Nitesh
    You are using an older version of the theme.
    Please update your theme or
    Thread Link:
    FTP detail:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check and resolve your issue.
  4. ipotent
    ipotent Guest
    I was having same issue...only not getting warning...just automatically redirected to home page. Here is the solution I used:
    You just need to edit lines 188 and 189 of dashboard_functons.php (found in /library/controls/dashboard) to the following:
    Line 188
    <span class="modify"><a href="<?php echo home_url("/dasboard/?page_id=$page_id&action=edit&pid=" . $listing->ID); ?>"><?php echo EDIT; ?></a>&nbsp;|&nbsp;
    Line 189
    <a href="<?php echo home_url("/dasboard/?page_id=$page_id&action=delete&pid=" . $listing->ID); ?>"><?php echo DELETE; ?></a>&nbsp;|&nbsp;<a target="new" href="<?php echo $listing->guid; ?>"><?php echo VIEW; ?></a></span></td>
  5. aliounn
    aliounn Member
    Hi ipotent,
    Warning disappeared without doing anything, i don't know what happened!
    can you tell me what you really did with these two lines (188,189).
    thank you
