About multi-languages need a help
Discussion in 'Dzonia WordPress Theme' started by artter, Jul 3, 2014.
  1. artter
    artter New Member
    I need three languages selectable on my site, english, chinese and french. I tried the Polylang plugin, unfortunately the 90 percent of memory was used up ! I had to restart the VPS and remove that plugin.
    How to solve this problem? Please give me a help.
    Simon
    Dzonia user
    My site: www.arttlabs.com
  3. artter
    artter New Member
    Hi, thanks for your reply.
    The qT's editor can't work, the content of different languages on the page is the same. I reinstalled the Polylang and it works now. Here is the CN page : http://www.arttlabs.com/zh
    I found that the slider, first and second featured sections on home page can't support multi-languages. I have no idea.o_O
  4. Gourav
    Our themes are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin.
    Or
    You can also contact to plugin related support forum. They will help you.
    Gourav Shrivastava
