Activated static front page, blog disappeared
Discussion in 'Figero WordPress Theme' started by daria369, Feb 4, 2014.
  1. daria369
    daria369 Member
    I activated the static front/home page in Figero pro theme and now the whole blog disappeared. I know I messed up one of the settings but have no idea how to fix this.
    Please help, thanks!
    Go to the Appearance > Theme Options > General Settings panel in your dashboard and turn OFF the Front Page.
  3. daria369
    daria369 Member
    I did that and now my home page is a blog again, and the static page with product slider is gone.
  4. Piyush
    You can do two things either display default front page in which the theme slider will display
    or you can display any other static page as home page.
    If you want to show default front page as home page then go to the Appearance > Theme Options > General Settings panel in your dashboard and turn ON the Front Page.
    And after that go to the Settings > Reading panel in your dashboard and set reading setting as shown in image given below.
    This will display the theme default front page.
    If you want to display your static page as a home page then
    go to the Appearance > Theme Options > General Settings panel in your dashboard and turn OFF the Front Page.
    And after that go to the Settings > Reading panel in your dashboard and select your static page from there for front page display.
    It will hide the default front page and display you static page as a home page.
