Active links on menu
Discussion in 'Andrina WordPress Theme' started by mindshop, Sep 10, 2013.
  1. mindshop
    mindshop New Member
    Italy
    Dear support,
    how do you create a not-clickable section name in the menu?
    For instance:
    - Section name (not active link)
    - Page A (active link)
    - Page B (active link)
    Thank you in advance.
    Go to Appearance > Menus
    and create a custom menu.
    On the custom menu add the pages with the links that you want.
    The trick is that it won't let you create any page without a link, so you have to give it a random link, add it to the custom menu, and once you added it edit it and delete the URL.
    That should make your button unclickable like you want it.
  3. mindshop
    mindshop New Member
    Italy
    Thank you for your reply!
    How do you delete the URL?
  4. Nitesh
    Please follow image instructions.
  5. mindshop
    mindshop New Member
    Italy
    Thank you for your prompt answer Nitesh!
    My menu is slighty different and can't set the attribute custom on the page:
  6. Piyush
    Firstly Go to Appearance > Menus
    See the image for reference.
  7. mindshop
    mindshop New Member
    Italy
    Perfect, it works! :)
    Thank you for your help!
