Attached is a screen shot where it says that my ad has expired. I set the settings so ads expire after 20 years. Why does it say that it has expired? I do not want them ever to expire. How do I make it so they never expire? Why did this one expire although I set it for 20 YEARS? How do I set it so that ads never expire? Also, I added 2 images to that ad and only 1 is appearing on the slider. Is that because I added it after it expired?
Hello, Go to Classified > Classified and click on "Edit" option of desired Ad and follow the instruction as shown in image given below This will solve your issue.. It is not possible to set ads never expire. Thanks & Regards Gourav Shrivastava
Thank you Gourav! Final questions…. what is the longest that an ad can stay active? By leaving it blank, when will that make an ad expire?
Hello, It takes the same time period that you have enter in "Ad Active Period" in your dashboard > Settings > Pricing. Thanks & Regards Gourav Shrivastava
So, can I make it 500 years or 10,000 years? What do you recommend if I do want it to be active forever?
Hello, Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. Thanks & Regards Gourav Shrivastava
What is the longest that it can stay active? Can you please provide me with a number / length of time? It provides me an area to input years. However, you say that I can not input 500 years. Please answer both questions: 1. What is the exact maximum limit of time currently? With does the current code allow for? 2. How much will you charge me for the custom code?
Hello, It is 25 years and it is WordPress default maximum time for any custom post, So it is not possible to change that limit. I hope you can understood. Thanks & Regards Gourav Shrivastava
Ok. Thank you. I set it for 25 years. In my back end, it says that this ad has expired. http://earthpossible.com/ad/alternative-economic-model-pout-eco-village/ I erased the expiry date. Also, In the backend I set it to the maximum of 25 years. 1. Why has it expired? 2. How can I make an expired ad active again? It may not be a problem. It looks like it is still active for the end user. I checked on a friend's computer and I was able to find the ad.
1. I created a test ad and it says that it has expired around 1 minute after I published it. I erased the expiry date. I left it blank. Can you log on to the back end and take a look? I want to learn what I did wrong. 2. How do I renew an expired ad? Attached is a screen shot. You can see that al of my ads are expired
Hello, Sorry for delay, Please provide the following information listed below. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] I will check your issue. Thanks & Regards Gourav Shrivastava
Hello, We have checked your dashboard and find that problem is happening due to listing expiry date. It means if user is creating listing from frontend then there is no need of add expiry date in listing edit area but if admin create listing from backend then expiry date is also cumpulsory. So, please add expiry date if you create listing from backend This will solve your issue. Thanks & Regards Gourav Shrivastava
