Ad Settings
Discussion in 'GeoCraft WordPress Theme' started by frannyp57, Oct 11, 2017.
  1. frannyp57
    frannyp57 New Member
    I have added two ad banner codes in Ad Setting (see attached screenshot) but can't see where they are displayed. I have clicked on Homepage and Listing pages but the ads do not appear anywhere.
    A second query. Other than the two areas to place ads in the two fields in Ad Settings, where else can I add other banner or RSS feed ads? Is it a case of adding the code into a Widget?
    Frank
  2. akbar92
    Hi Frank,
    We already have your website credentials so that I have logged in to your website, it seems like there is something missing in your code. I have checked that section with my code, it is working fine.
    So, you are requested to check your code again and let me know for the same if the problem persists.
    Yes, you can use Ad code with the text widget.
    Thanks & Regards,
    Akbar
  3. frannyp57
    Hi Akbar,
    I've checked the codes and they are OK. All I did was copy and paste them from the advertiser. I'm not sure what you mean by "I have checked that section with my code, it is working fine".
    Do you mean that you can see the ads on the pages? For example, when I look at say a business listing - http://chesterlifestyle.com/listing/eat-chester-shanghai-restaurant/ - where is the advert? I can't see it.
    Frank
  4. akbar92
