How do I add content in the pink highlighted area? I want to add an image and some text above the slider and below the category menu. Could you let me know which files need to be updated so I can examine the code?
Hello, Warm Wishes From InkThemes, You will need to make changes in the coding of the file templates-slider.php I have attached a screenshot for your help kindly have a look at it. If you are not able to make the changes of your own then from our end the changes will contain some charges. So just let us know if you are unable to make the changes, we will then let you know the charges. Regards, Shemaela InkThemes.com
