Add credit/debit logos
Discussion in 'Cloriato WordPress Theme' started by nfelectrical, Jan 16, 2014.
  1. nfelectrical
    nfelectrical New Member
    Can I add credit/debit card logos/images to the theme? Preferably where the search bar is or at the bottom right hand corner of the footer.
    Go to the Appearance > Widgets panel in your dashboard and
    drag & drop text widget in the Third Footer Widget Area
    and then paste the image code given below in the content area of text widget .
    <img src="Enter your image URL adress here">
