Add customized header
Discussion in 'Appointway WordPress Theme' started by simplyruschelle, Feb 26, 2014.
  1. simplyruschelle
    simplyruschelle New Member
    I am looking to change the header to my site completely to a customized header (please refer to attached image).[​IMG]
    Any way to do this? I see there is not a 'header' option in the settings area.
    Thanks!
  3. simplyruschelle
    Hi Piyush,
    Thanks! I figured it was that file, just not sure where to add the image file, what dimensions work best, and what code to use. Is this something you can know?
    Thanks again!!
  4. Piyush
  5. grafixbiz
    grafixbiz New Member
    I need to change the header to an image on this theme too so interested in the solution here.
    I have tried several different things in the css for the header, header container but nothing happens - confused. com
  6. simplyruschelle
    Hi Piyush, so basically I want to change the header (image of default header) to customized one - so the width would be the same but the height will be twice as big.
    From this:
    To this:
    Thanks!!
  7. Piyush
    Go to the header.php file present in your theme directory and paste the code given below in this file as shown in the image given below.
    <img class="header_img" src="Enter your image URL address here">
  8. simplyruschelle
    Thanks Piyush! Still running into an issue. I added the image code and this is still happening (see image). The dimensions for the image was 1790px by 175px. Also added the code so you can see what I did. Thanks!
    Image link: http://ow.ly/i/4Ln2b
    <?php
    * The Header for our theme.
    * Displays all of the <head> section and everything up till <div id="main">
    <!DOCTYPE html>
    <html <?php language_attributes(); ?> xmlns="http://www.w3.org/1999/xhtml">
    <head>
            <meta charset="<?php bloginfo('charset'); ?>" />
            <title>
                <?php wp_title('&#124;', true, 'right'); ?><?php bloginfo('name'); ?>
            </title>
            <?php if (is_front_page()) { ?>
                <?php if (inkthemes_get_option('inkthemes_keyword') != '') { ?>
                    <meta name="keywords" content="<?php echo inkthemes_get_option('inkthemes_keyword'); ?>" />
                <?php } else {
                <?php if (inkthemes_get_option('inkthemes_description') != '') { ?>
                    <meta name="description" content="<?php echo inkthemes_get_option('inkthemes_description'); ?>" />
                <?php } else {
                <?php if (inkthemes_get_option('inkthemes_author') != '') { ?>
                    <meta name="author" content="<?php echo inkthemes_get_option('inkthemes_author'); ?>" />
                <?php } else {
            <?php } ?>
            <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0" />
            <link rel="profile" href="http://gmpg.org/xfn/11" />
            <link rel="pingback" href="<?php bloginfo('pingback_url'); ?>" />
            <link rel="stylesheet" type="text/css" media="all" href="<?php bloginfo('stylesheet_url'); ?>" />
            <?php wp_head(); ?>
        </head>
        <body <?php body_class(); ?> style="background:url('<?php if (inkthemes_get_option('inkthemes_bodybg') != '') {
        echo inkthemes_get_option('inkthemes_bodybg');
    } else { } ?>');">
    <div class="header_container">
    <div class="container_24">
    [COLOR=#ff0000]<div class="grid_24">[/COLOR]
    [COLOR=#ff0000]<div class="header">[/COLOR]
    [COLOR=#ff0000]          [/COLOR][COLOR=#ff0000]http://simplybeconsulting.com/wp-content/uploads/2014/03/sbc-header.jpg[/COLOR]
    [COLOR=#ff0000]</div>[/COLOR]
    <div class="clear"></div>
    </div>
    </div>
    <div class="menu_container">
    <div class="menu_bar">
    <div id="MainNav">
    <a href="#" class="mobile_nav closed">Pages Navigation Menu<span></span></a>
    <?php inkthemes_nav(); ?>
    </div>
    </div>
    </div>
    </div>
    </div>
    </div>
  9. simplyruschelle
    Oops sent the wrong code. Here is the one I used:
     <?php
    <!DOCTYPE html>
    <head>
            <title>
            </title>
                <?php } else {
                <?php } else {
                <?php } else {
            <?php } ?>
            <?php wp_head(); ?>
        </head>
    } else { } ?>');">
              <img class="header_img" src="http://simplybeconsulting.com/wp-content/uploads/2014/03/sbc-header.jpg"> </div>
    </div>
    </div>
    </div>
    <div id="MainNav">
    </div>
    </div>
    </div>
    </div>
    </div>
    </div>
  10. Piyush
  11. simplyruschelle
    It's simplybeconsulting.com. I put the original code back. Should I use the edited code again? Let me know. Thanks!
  12. Piyush
    Yes, please apply the code given above (#7) in the header.php file
    and then paste the code given below in Custom CSS section
    body > div.header_container > div > div.grid_24 > div > img {
    width: 100%;
  13. simplyruschelle
    Thanks again Piyush. I really appreciate you taking the time to work on this with me!!
    Looks like that did it! :)
  14. simplyruschelle
    Ugh!! Sorry to bother again. :confused:
    I just realize that the header size I had was 1790 x 175px. But the container of the template won't allow for a header wider than ~100px. Where can I adjust this? Thanks!!
  15. Piyush
    You can use the header image of maximum width 1100 px.
    Theme is implemented on the grid system, if we try to change its size then theme will loose its layout.
    So not possible to exceed its width greater than 1100 pixel.
