Hello, In the right side of the footer we have used social icon so you can't add the text there, We would suggest you to add the text in "Footer widget area". Just go to "Appearance -> Widget" And chose Text Widget and drag drop to "Third Footer Widget area" And then you can write the text there, it will show the text to the bottom right side of the theme.
I have tried this and it works. thank you for your assistance. Is there a way to remove the "Bolding" of the link text ? thank you in advance.
Please explain your problem with the help of screenshot, where you want to remove the"Bolding" of the link text, so that we can give you the exact solution.
hi Gourav, I've attached a screen shot . The links are at the bottom right (Calendar / Update). they are Bolded compared to the service area names just above them. I would like to remove the Bolding if possible.
