Add fields to create membership AND move it to its own page?
Discussion in 'Subscribely v2 WordPress Theme' started by flipper828, May 17, 2014.
  1. flipper828
    flipper828 Guest
    I am absolutely brand new to WP but not to web design and building.
    I have a website built but needed a full back-end subscription service such as the one Subscribley is offering.
    I was hoping to be able to incorporate your system into the site I have built.
    The site is http://critiquebykids.com/ But I see this is going to be an uphill battle. So I am sure I will be here in the forums time and time again because I will tackle one thing at a time.
    If you will look at the above site, what I am asking may make better sense.
    I want to add a lot more fields to the Sign Up form and I want it to be the child of another page.
    1-How do I add more fields to the sign up form? Will the new fields be stored in the database?
    2-How do I create a page for the sign up form?
    3-I like the body of the login page but I want to remove the sign up form and replace with a link to the parent page of the sign up form. Is this possible?
    Last question. If what I am wanting is not possible with this template, I won't be angry...I was buying on the chance it might work for my current project. If it won't I am sure I will be able to use the template for some future projects.
    Also, if I can't get what I want with this template, do you have any suggestions on customizable system that might incorporate into the current website. The friend I am doing this for LOVES the look of the current site.
    Thank you in advance for any help or advice you can give me.
    Claudia
    PS in the current site, I am using include files for the header, body and footer. I hope this won't add more to the problem.
    Firstly, It is not possible to add more field in sign up form.
    It create its own page when you install the "Ink Member Pro" plugin.
    Yes, it work fine with other WordPress theme also, just download the Ink Member plugin and upload it.
    Gourav Shrivastava
