Add image below tap-to-call phone option (upper right)
Discussion in 'RoadFighter WordPress Theme' started by gloryous, Aug 21, 2015.
  1. gloryous
    gloryous Member
    I need to add a wide and very narrow image (500px by 36px) below the tap-to-call phone option (upper right) and above the nav bar for my client. (The image -- of text -- is attached for reference as well as another image showing its placement.) How can I do this?
    Thank you,
    Glory
  2. nitin
    nitin Guest
    Everything is possible with us, and fixing your issue is really very easy.
    It requires some customization in the source code of the theme.
    Nitin
  3. nitin
    nitin Guest
    Hi Glory,
    Thank you for sending the credentials.
    I have made changes in your website as per your requirement.:)
    Kindly check and reply.
    Regards!
    Nitin
  4. gloryous
    gloryous Member
    Nitin,
    The text-as-image is perfectly placed and looks quite nice on a desktop. Thank you for this.
    HOWEVER...
    ...when viewing the site on mobile devices, I have some real concerns:
    • With an Android (Samsung) mobile phone, this text-as-image remains too large and does not reduce in size proportionally like other images. In addition, it's wreaking havoc with the visual presentation on the smaller screen, causing other components (text as well as imags) to reduce much more than is necessary.
    • With an Apple device (an iPod 5s), the text-as-image seems not to reduce at all and is visible only when swiping the screen to the left.
    • On a Kindle HD Fire, in landscape mode it looks good. In portrait mode, it's problematic. The top of the site becomes jumbled with content on top of content on top of images (the sliders). And again, the text-as-image that you placed for me is off-screen and visible only when swiping the screen to the left.
    Is there anything more that can be done?
    Appreciating your efforts so far, Nitin.
    Glory
  5. nitin
    nitin Guest
    Hi Glory,
    Sad to learn that you were in the issue.
    But, you would be glad to know, that as we had your dashboard credentials (as we have recently done the changes to your website).
    We thought it's better to save your time and efforts. So, for you we have made the required changes as per your requirements.
    The website is now fully functional on the devices which you preferred.
    Hope this solves your issue.
    Nitin
  6. gloryous
    gloryous Member
    Nitin,
    Thanks for the additional changes you've made!
    Much appreciated,
    Glory
