Add Listing - Custom Post Type
Discussion in 'GeoCraft WordPress Theme' started by molatin, Nov 12, 2013.
  1. molatin
    molatin Member
    We used a plugin called Custom Post Type UI so that we could create custom posts with different Categories (e.g. business location, business type) . Everything is working properly but we noticed that when a user adds a listing, the category list is empty.
    So how can we replace the category list to show the category list for the custom post types.
  2. molatin
    molatin Member
    Hi support - can you help here please? thanks
  3. tobyb
    tobyb Active Member
    World Wide
    Hi Mo, did you try adding the category without the slug?
    Toby
  4. Nitesh
    Hello Molatin,
    Nitesh Raghuwanshi
  5. molatin
    molatin Member
    Thanks Toby - we'll try that.
  6. molatin
    molatin Member
    Thanks Nitesh - any guidance you can offer us on how to do that? Thank you
  7. molatin
    molatin Member
    Nudge
  8. molatin
    molatin Member
    Here is a diagram of what we are aiming for
  9. molatin
    molatin Member
    Any response for this would be greatly appreciated
  10. molatin
    molatin Member
    So we are still having the same problem with the categories not showing up when adding a new listing (Add New Listing ss.jpg)
    As I mentioned earlier we have new taxonomies through a plugin (Business Listings ss.jpg) but it is still in the same post type - 'Listings'
    I was able to talk with the plugin author and he mentioned we need to add the taxonomies into the query
    I'm not sure if this is the correct file (listing_submit_form.php) that we need to edit but I think we just need to add the new taxonomies into the query so that it would show when adding new listings
    Please guide us on how we can do this. Thank You.
  11. Nitesh
    PM sent.
    Nitesh Raghuwanshi
  12. molatin
    molatin Member
    Hi Nitesh,
    Any updates on this? We have a big project waiting to go ahead and need this last piece working and tested so we can launch
  13. molatin
    molatin Member
  14. Piyush
    You are asking for a plugin integration in the theme, which don't come under our custom support area.
    You can hire freelancer for it.
