Add Listing issue
Discussion in 'GeoCraft WordPress Theme' started by aster media, Jan 15, 2016.
  1. aster media
    aster media Member
    Pls check: http://genesis2church.eu/
    Selecting add listing does not click through to the page.
    Pls advise what I can do to make that happen?
    Best wishes,
    Steven
    Hello Steven,
    Would you please send your dashboard credentials at our mail id with this thread link and we will resolve it for you...
  3. rogerb
    rogerb Active Member
    Have you set and saved your permalinks Steven as the button link doesn't have a page id number to go to?
    It defaults to the home page because of this. In the IDE go to settings > Permalinks
    Hope this helps.
    Yes, Rogerb is absolutely right....
    This may also help you...
  5. aster media
    aster media Member
    Set and saved ofcourse, but the problem persists.
    I do notice that custom structure setting does not allow saving where all others do.
    Dashboard credentials at our mail id sent.
  6. priya
    Hello Steven,
    We will check this issue in your site and will get back to you soon...
  7. aster media
    aster media Member
    Any news? I forgot to check this and made a new post about it. Pls delete it.
    Steven
  8. priya
    Hello Steven,
    I am unable to access your dashboard through your provided credentials as it shows an error message....
    Kindly check your credentials..
  9. priya
    Hello! Steven,
    We have resolved your issue from your site:http://genesis2church.eu/ by installing a fresh copy of the theme,
    You are not supposed to delete the default pages comes with the theme, as there are some page templates assigned on them, you can rename the title, or if you don't want to show any of them, then just create your custom menu which doesn't contain any of them.
    Hope you understand.
    Regarding your other sites, we are still unable to open them, please let us know if your host provider resolved the issue, so that we can check the functionality of the theme there.
  10. aster media
    aster media Member
    Thanks Priyanka, just checked in to this thread now. My provider proposes that this could be a security thing on their side. In order to resolve it they require the IP address of the computer/location from where your developers login. If they have that, they can resolve it. I hope you can give the IP address for me to forward.
    Best wishes,
    Steven
  11. priya
    Sure Steven,
    Here's it...182.74.72.186
  12. aster media
    aster media Member
    Thank you Priyanka. Your IP has been whitelisted.
  13. priya
    Hello Steven,
    Sent you an email..
    Kindly check your email..
