Add more slides
Discussion in 'Cloriato WordPress Theme' started by imogen, Oct 25, 2013.
  1. imogen
    imogen Member
    Hi, using the pro version..
    Am I able to add more slides so I have more then 6 slides in my theme options?
  3. imogen
    imogen Member
    I have copied the coding to make another slide and slide 7 now appears in theme options.. but it won't show up on the main home page. Is there a way to show this on the home page? Thanks.
  4. Piyush
