Add More than 5 Slides
Discussion in 'Infoway WordPress Theme' started by mocklin, Sep 12, 2013.
  1. mocklin
    mocklin New Member
    How do I add a 6 or 7th slide in infoway? I tried replicating the slider code in header.php to add slider6 but didn't work. Can you show me what i need to edit please? Thanks!
  3. mocklin
    mocklin New Member
    can you point me in the right direction? I found the slides in frontpage.php I added a slide to this:
    <div id="featured">
    <?php if ((inkthemes_get_option('inkthemes_slideimage1') != '') || (inkthemes_get_option('inkthemes_slideimage2') != '') || (inkthemes_get_option('inkthemes_slideimage3') != '') || (inkthemes_get_option('inkthemes_slideimage4') != '') || (inkthemes_get_option('inkthemes_slideimage5') != '') (inkthemes_get_option('inkthemes_slideimage6') != '') ||) { ?>
    and repeated this: and changed it to sliderdesc6.
    <?php if (inkthemes_get_option('inkthemes_slidedesc5') != '') { ?>
    <p> <?php echo stripslashes(inkthemes_get_option('inkthemes_slidedesc5')); ?></p>
    <?php } else { ?>
    <p>Hey Guys, I am a back again to about</p>
    <?php } ?>
    </div></a></li>
    is there something else that needs to be changed? I would think this would give me an extra slider unless this is coded somewhere else?
  4. Gourav
    If we try to add extra slides on InfoWay theme homepage slider then it will breaks its design, So it is not possible to add extra slides on that slider.
    But it is possible to add new slider on the theme, If you want to do that then, You can use WP Slider Plugin, download it from WordPress.org and upload it.
    http://wordpress.org/plugins/simple-slider-ssp/
  5. mocklin
    mocklin New Member
    okay, thank you.
