Add more than 6 images to slider
Discussion in 'GoldenEagle WordPress Theme' started by tt619, Jan 17, 2013.
  1. tt619
    tt619 New Member
    Is it possible to add more than six images to the slider in Golden Eagle pro?
    If this isn't something you're able to do then you would need to hire a developer for this.
  3. tt619
    tt619 New Member
    I found the answer- copy in the code used to call images 1-6 (inkthemes_slideimage) and change the number to seven in the front-page.php. Then do the same with the code following the //first Slider to //Sixth Slider in theme-options.php.
