Hi, Code is given below.. Code: .home_content_wrapper { padding-bottom: 29px; } Thanks & Regards! Priyanka InkThemes.com
Hi, Use below code.. Code: .footer_wrapper .footer { padding-top: 70px; } Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
Hi, Please clear your cache first and check the changes after that.. Thanks & Regards! Priyanka InkThemes.com
I see what's happening...when I add the second code you gave me, it adds a padding above the footer text...adding more grey space. What I want is more light green added...not grey. I'm attaching a picture of what it looks like before the code then after.
Hi, Sorry, I am unable to open your screenshot.. Kindly requested to resend it.. Thanks & Regards! Priyanka InkThemes.com
Yes, it is.. As per your requirement, I would like to tell you that the first code (was provided in my first post) will work.. Code: .home_content_wrapper { padding-bottom: 80px; } So you are kindly suggested to do this change once again and remove the second provided code from your dashboard.. Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
