Add Phone & Opening times to right of Logo
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by leonkill2000, Feb 11, 2016.
  1. leonkill2000
    leonkill2000 Member
    Hi
    I have moved my Logo to above the Menu.
    I then added contact phone & opening times to the logo.
    This has made the Logo too wide for the mobile view.
    Is it possible to add Phone & Opening times to the far right hand side of the Logo (Not attached to the logo)
    Many thanks
    Leonie
    Hello Leonie,
  3. leonkill2000
    leonkill2000 Member
  4. leonkill2000
    leonkill2000 Member
    I have noticed that the menu has gone back up to the top !!
    I originally had it sitting underneath the Logo (which the client prefers)
    this is the code I entered to change the position of the Logo
    .header .logo img {
    max-width: 960px;
    height: auto;
    I am using a child theme
    cheers Leonie
  5. priya
    Hello Leonie,
    I have done some changes in your site...
    Kindly check your site and acknowledge the same..
  6. leonkill2000
    leonkill2000 Member
    Thanks Priya for your prompt response.
    I will let my client have a look :)
    cheers Leonie
  7. priya
    Ok Leonie..
  8. leonkill2000
    leonkill2000 Member
    Hi Priya
    After talking to my client we ask if the following is possible.
    I have changed the Logo back to the original one as the adjusted one with the opening times was too small on the main website though it looked OK on the mobile theme.
    I have also deleted all of my css except one (I have kept them all in a text doc incl your changes)
    I have made another logo with the Opening times and telephone number. (uploaded in the media area)
    Is it possible to have this logo showing on the far right hand side of the website level with the main Logo?
    Also can a Search button be incorprated in this area as well ??
    We are hoping that this will sit better on the mobile view.
    Another request (sorry about all these changes) can the menu be positioned just above the slider and not at the top.
    This would also place the Logo above the menu
    Really appreciate your help in this - you all do a great job in dealing with all of our many and varied requests... :)
    cheers Leonie
  9. priya
    Hello Leonie,
    Thanks for your appreciation...:)
    Let me tell you, Leonie, that all your required changes are possible with some source code customization in the theme...
    So if you want we can do it for you, but for that, we need to access your dashboard..
    Please send us your credentials at [email protected] and we will do it for you..
  10. leonkill2000
    leonkill2000 Member
    Hi Priya
    I have emailed this info to you :)
    cheers Leonie
  11. priya
    Thanks for the details Leonie..
    We will get back to you soon...
  12. leonkill2000
    leonkill2000 Member
    OK thanks Priya
    I will also be still working on the sie - hope this is OK
    I also noticed that the theme had gone back to the parent theme
    I had it active for the child theme
    I presume this was because the IT guys were working on it
    cheers Leonie
  13. priya
    Sorry for that Leonie..
    Yes, our developers are working on your site..
  14. priya
    Hello Leonie,
    You would be glad to know that we have made changes in your site as per your requirement..
  15. leonkill2000
    leonkill2000 Member
    Thanks Priya
    Sorry for the late response its been bedlam here...
    Many thanks to the developers for making these changes
    my client is very happy with their mobile view now.
    cheers Leonie
  16. priya
    You're welcome Leonie..
