Hi, I'd like to put a countdown clock on the front page of the theme (I have the coding for the plugin) how would I do this? Many thanks in advance
Hi, Greetings from InkThemes, It would be our pleasure to serve you. To be specific to your answer, let me tell you that you cannot directly punch the coding of the plugin into your theme, unless it is a shortcode. It can be done by adding widgets also. Kindly let me know which plugin you are using, so that I could further assist you. Thanks & Regards! Nitin InkThemes.com
Hi, thank you. here is the coding for the plugin - tried to use the widget for front page.. coding shows but the plugin doesn't. [wpc_countdown theme="flat-colors" now="1425299474651" end="6659.5" bg="#fff" padding="5"] Wp Custom Countdown is the plugin
Hello, Greetings from InkThemes! Please use this code (given below) for once in your "front.php" page (wherever you want to add the timer) through Theme Editor (Appearance=>Theme Editor). Code: <?php echo do_shortcode('[wpc_countdown theme="flat-colors" now="1425299474651" end="6659.5" bg="#fff" padding="5"]'); ?> For your information, I am using "WP-Editor" plugin to edit files. You can also download and use it from the link https://wordpress.org/plugins/wp-editor/. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thank you. Wanted to add the plugin underneath the 3 images on the front page (ESOS, Energy Consultancy, Team) Where would I need to put the code in front.php?
Hello, Please follow the screenshot given below. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
