Add rtl layout for Arabic language
Discussion in 'ClassiCraft WordPress Theme' started by M5LASTER, Jun 16, 2014.
  1. M5LASTER
    M5LASTER Member
    Hi guys,
    Thanks in advance. I'm still building my multi language site in English and Arabic. I built it first in English and now I I want to add the Arabic part. I installed the WPML plugin and the translation is going well, but the site layout is not correct. The layout is left-to-right or (ltr) for English and for the Arabic side. I would like to convert what's needed from ltr to rtl, so that when an user switches to Arabic, the lay out also converts to rtl.
    Kindly, help with this issue.
    Mike
    Hello Mike,
    Classicraft theme already contain rtl option.
    You can switch it from
    Appearance > Theme options > styling options > Theme Rtl
    Nitesh Raghuwanshi
  3. M5LASTER
    M5LASTER Member
    Hi Nitesh,
    Thanks for your reply. This option doesn't fully solve the issue.
    1. This option will switch to rtl style regardless of what language is selected even for English language.
    2. This option will switch the top menu to rtl, but will not switch the location of the side widgets to the opposite side. Or any of the tables within the page.
    Can you guide me how to fix the 2 issues?
    Thanks in advance.
    Mike
  4. M5LASTER
    M5LASTER Member
    Hi Nitesh,
    Can I get an update on this?
    Mike
  5. Nitesh
    Hello Mike,
    Nitesh Raghuwanshi
  6. M5LASTER
    M5LASTER Member
    Thanks!
