Add Text to Appointment Module?
Discussion in 'Appointway WordPress Theme' started by filmworks7, Apr 8, 2016.
  1. filmworks7
    filmworks7 Member
    Right Under where it says " Book Your Appointment"
    I would like to put ***For Existing Clients Only (in a color that that pops out as white won't)
    Can you tell me how I can do this?
    Thanks!
    After this, paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    li.textheading p {
        color: red !important;
    Note: Change the color as per your interest..
  3. filmworks7
    filmworks7 Member
    Thanks Priyanka.
    Got the text in there.
    Color change did not work though. I did put it in the custom CSS and save.
    Was the code you gave me right?
    Also I noticed under FORM STYLES it says you can change color for the whole form.
    I tried 2 different colors and saved but it does not change the black color frame.
    Anything to do about that?
    Yes, given code is absolutely right as it works perfectly at our end...
    So you are kindly requested to clear your cache and check after that..
    For the second issue,
    We have already resolved this issue in latest version of the theme,
    So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members are
    Download the AppointWay theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder classicraft like appointway_new,
    Again, you would need to create a zip file of that renamed folder (say: appointway_new.zip),
    Then, activate your theme,
