Hello, Go to the Appearance > Widgets Drag widgets and drop them in the first, second and third widget area, It will automatically display at your footer. Thanks & Regards Gourav Shrivastava
Thanks, maybe I have not explained well. I want to add the widget in a column of the home page, for example the right column of the "Home page two cols". How can I do? Thanks & regards.
Hello, Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry.
Piyush: I have a similar question. Is it possible to get the latest blog post to display in one of the homepage columns? Kim
Hello, Unfortunately, it is also not possible to display the latest blog posts in one of the homepage columns with our theme. But you can display your latest blog posts in the footer widget area through the Special Recent Posts plugin. Download Special Recent Posts plugin from http://wordpress.org/extend/plugins/special-recent-posts/ and install it in your dashboard from plugins section. Use its feature in the widget section.
