Hi there On that particular page: http://aromafoodgroup.com/media/ I would like to move our contact details and create a separate box that can sit on the right hand side (underneath the search) so it gets separated from the press articles. Can you let me know if and how that can be done? Thank you Anna
Hello Anna, For this go to the Appearance > Widgets drag text widget. Drop it in the primary or secondary widget area. And add your contact detail in it. Thanks & Regards Nitesh Raghuwanshi
