Adding a third listing, again...
Discussion in 'GeoCraft WordPress Theme' started by henrique25, Jun 20, 2014.
  1. henrique25
    henrique25 Member
    Hello!
    Due to a detail I forgot about, I'm reactivating the thread I had started prior to this.
    Here's the original text:
    "I see that there are two listing types: Free and Premium.
    My idea would be to insert an intermediate type (Standard) which would not allow for the lead form to show (therefore, only Premium users would be able to have lead captures).
    Is there a way this can be done?
    Note: I am not allowing users to add their listing (I've removed the link). Only I am able to do that.
    Thank you in advance,
    Henrique"
  2. henrique25
    henrique25 Member
    Another thing... in the event of not being able to add a third listing type, is there a way to define what is visible and what is not, in the free listings?
  3. henrique25
    henrique25 Member
    Also, could you please tell me if I can remove the "publish date" from my listings?
  4. Nitesh
    It is not possible to add third listing type. But yes you can set what to show in the free listings. For it go to the
    Geocraft settings > Custom fields > edit fields and check "Enable for free listing".
    It will show that particular field for free listing.
    For publish date
    Paste this code in Custom CSS
    div.tbl_des tr:nth-child(2){
    display:none;
    Nitesh Raghuwanshi
  5. henrique25
    henrique25 Member
    Cheers!
