Hi, I wanted to ask if its possible to change the static testimonial section on the home page of Colorway theme to an auto-rotating testimonials which displays different testimonials that auto-rotate? If so, how do I set it up? Thanks
Unfortunately there isn't a way to do that with this theme unless you custom code something up. Sorry. If this isn't something you're able to do then you would need to hire a developer for this. Take care.
