Adding Clickable Logos to Footer
Discussion in 'BlackBird WordPress Theme' started by chrissann, Mar 10, 2014.
  1. chrissann
    chrissann New Member
    My website is not published yet, so I can't provide a link.
    How can I add logos to the footer space? I would like these logos to be "clickable" links to take you to their website by opening a new page/tab.
    Thank you,
    Chrissann
    Hello Chrissann,
    Go to the Appearance > Widgets panel in your dashboard and drag Text widget and drop it in the Footer Widget Area section
    and then paste the code given below in the content area of text widget.
    <a href="Enter The URL Link Of Another Page "><img src="Enter The URL Address of Logo Image  Here "> </a>
    See the image for reference
  3. chrissann
    Ok, thank you, this worked, but I have three logos I'd like to add, that I was going to place in the three separate footer areas. How can I have them sized and spaced evenly? Currently, just one is coming out way to large and taking up the entire space. All of the logos are long and horizontal...
  4. Piyush
    Firstly add all three logo through the same process as given in the above post (#2) and then
    share us your website link so that we can check your issue and provide you exact solution,
    if you are still not published your website yet then you can specify your issue with the help of screenshot images.
