Adding disclaimer to top of site
Discussion in 'Poloray WordPress Theme' started by tonigel, Sep 15, 2015.
  1. tonigel
    tonigel New Member
    With new google adwords policy updates, where are insisting I add a disclaimer to the top of my website.
    Is there a way to add a line of text over the logo and menu?
    (Using poloray theme.).
  2. nitin
    nitin Guest
    It would be our pleasure to serve you. Everything is possible with us.
    You have two options:-
    1. You can get it hard-coded in your theme. It requires some customization in the source code of the theme. This will be fix and you cannot change it easily.
    2. We can provide you with an option in the 'Theme Options' panel.(Chargeable)
    If you opt for the second option, you will get the option to enter and alter/control the text whenever you want. This will be responsive as well, without the risk of affecting the other features of your website.
    Do let me know if you agree then, I will tell you the amount and mode of payment.
    Nitin
