Hello, Greetings from InkThemes! You can easily remove 3 labels from your post and for that you just need to paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .blog .post .post_meta { display: none !important; } Regarding your second issue i.e. to add another place for the banner so let me that you that will be possible with source code customization in the theme. So please send us your dashboard credentials at [email protected] along with this thread link and we will do it for you. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
can someone help me remove the banner on top of the page. the 728.90 , i cant find where the code located
Hi, Greetings from InkThemes, Could you please provide us URL of your website along with some edited screenshot of your requirements, so that we can assist you accordingly? If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Looking forward to hear from you. Thanks & Regards! Nitin InkThemes.com
