Adding Images to "Top Right Contact Details"
Discussion in 'Infoway WordPress Theme' started by lkodsmann, Jun 23, 2016.
  1. lkodsmann
    lkodsmann Guest
    I want to manually add some social icons to this area, but when I put <img src="xxx"> code into this section in Appearance > Theme Options, it doesn't display on-screen.
    I've attached two screenshots so you can see what I mean... the first is a screenshot of the "Top Right Contact Details" section in the Theme Options panel, so you can see what I've entered... the second is a screenshot of the homepage, so you can see that the text content is rendering perfectly - but the image doesn't display.
    Thank you for your help!
  2. nitin
    nitin Guest
    As I can see in your <img src="#"> code, you have used '-' symbol instead of the '='
    Kindly replace the symbol to get the code working.
    Hope this helps...!
    Nitin
