Adding search bar or box for car models to engine oil theme
Discussion in 'InkThemes-Support Working Hours' started by abushwereb, Jul 7, 2017.
  1. abushwereb
    abushwereb New Member
    I have purchased the Engine Oil theme and would like to add search form or function for the customer to determine the type of engine oil for his car; i.e., the customer enters the car details (e.g. made, model, and year) in the search form and the result should be the type of oil most appropriate for his car. Please help!!
    Thank you.
    Al.
  2. akbar92
    Hope you are doing good...!
    As per your requirement, I would like to inform you that - This will require some source code customization in the theme which is time-consuming and would be done specially for you by our team, but there will be some charges.
    Do let me know if you agree then, I will tell you the amount and mode of payment.
    Looking forward to hear from you.
    Akbar
