Adjust slider speed/frequency
Discussion in 'Andrina WordPress Theme' started by firstpoint, Oct 8, 2014.
  1. firstpoint
    firstpoint New Member
    Is there a way to make the homepage slider transition more frequently? I can't find it in the code and there's no UI option.
    Thanks all.
  2. Pramod
    Pramod Guest
    Please follow below image to adjust slider speed.
    Pramod
      File size:
      98.2 KB
      7
  3. lrdjv2
    lrdjv2 New Member
    Hey there !
    Seemed to be a problem, because no "box" here above "Fisrt Slider Image" in the Slider Settings section. I have the pro version of Andrina. Is it normal ?
  4. Pramod
    Pramod Guest
    Hello ,
    If you are using pro version and not getting the slider speed section in theme option panel then please install a fresh and latest copy of theme if possible.
    Pramod
