First I would like to thank Gourav for answering all my questions so far, great support, thank you! I am wondering how can I change the speed of the slider images?
Go to Js > custom.js present in your theme directory and replace current code Code: //Flexslider //<![CDATA[ var $j = jQuery.noConflict(); $j("document").ready(function(){ $j('.flexslider').flexslider(); }); //]]> with Code: //Flexslider //<![CDATA[ var $j = jQuery.noConflict(); $j("document").ready(function(){ $j('.flexslider').flexslider({ animation: "slide", //String: Select your animation type, "fade" or "slide" slideDirection: "horizontal", //String: Select the sliding direction, "horizontal" or "vertical" slideshow: true, //Boolean: Animate slider automatically slideshowSpeed: 4000, //Integer: Set the speed of the slideshow cycling, in milliseconds animationDuration: 600, //Integer: Set the speed of animations, in milliseconds directionNav: false, //Boolean: Create navigation for previous/next navigation? (true/false) controlNav: false, //Boolean: Create navigation for paging control of each clide? Note: Leave true for manualControls usage keyboardNav: true, //Boolean: Allow slider navigating via keyboard left/right keys mousewheel: false, //Boolean: Allow slider navigating via mousewheel prevText: "Previous", //String: Set the text for the "previous" directionNav item nextText: "Next", //String: Set the text for the "next" directionNav item pausePlay: false, //Boolean: Create pause/play dynamic element pauseText: 'Pause', //String: Set the text for the "pause" pausePlay item playText: 'Play', //String: Set the text for the "play" pausePlay item randomize: false, //Boolean: Randomize slide order slideToStart: 0, //Integer: The slide that the slider should start on. Array notation (0 = first slide) animationLoop: true, //Boolean: Should the animation loop? If false, directionNav will received "disable" classes at either end pauseOnAction: true, //Boolean: Pause the slideshow when interacting with control elements, highly recommended. pauseOnHover: true }); }); //]]> //]]>
