Admin not having permission...
Discussion in 'GeoCraft WordPress Theme' started by webunet, Jan 23, 2014.
  1. webunet
    webunet Member
    Kalispell, Montana
    While logged in as the Admin, trying to modify info on this page, Geocraft Pro Theme Options, I changed the copyright year to 2014, but it will not let me save my changes. I get the message...
    Forbidden
    You don't have permission to access /wp-admin/admin.php on this server.
    Please assist, thanks,
    Tom
  3. webunet
    webunet Member
    Kalispell, Montana
    Gourav,
    Everything in that thread is 4-5 years old. I wouldn't trust any WP advice from that long ago. Do you have another suggestion, please?
    Tom
  4. rogerb
    rogerb Active Member
    When I had these problems it was either the Wordpress firewall plugin in use or more likely the .htaccess file which was restricting access - can't remember which exactly!
    Anyway, I deleted the .htaccess file and regained access again although you might want to note its contents first!
    I'm sure that this .htaccess file appeared after I used a plugin to check and harden the website - it did its job too well !
    Hope this helps in some way.
    Roger B
